Just got through reading, that is a great idea with the AC, I am going to ask you a few more questions about that. So did you ever end up going with batteries or are you running 100% off solar and just adjusting usage?I also live in Phoenix, and I'm also with SRP on the E27 TOU plan with "Net Metering." But the "Demand fee" is an ugly elephant in my electric bill making 70-100% of it.
Here are my experience and suggested solutions on how to mitigate it:
Mitigation of demand from utility with solar
Hi. I'm from Phoenix, AZ with 12.96kW grid-tied system up and running. It has 5 strings of panels and two SMA grid-tied inverters working in parallel. They are AC coupled before solar meter. It's a standard design recommended by SRP (utility company) published on their Web-site I'm on "Customer...diysolarforum.com
These are my numbers from the beginning of 2023 and my bill for June:
My house is 2,000 sq. ft., and I have three EVs in my household charged 100% at home. So, the bill included the EVs energy consumption.
More like 10-15 years as a generalization. They are economically viable if the delta between daytime power and nighttime power is over $0.10/kWh, and the demand charges might make them an even better sell at a lower delta.Batteries are very expensive, and the problem is that they degrade in 5-8 years. So, they are not economically reasonable.
It's not SRP. Everywhere with good sun faces the same issue. They can supply daylight loads with 2 cent solar. If they pay someone more, either in cash or net metering credits, they have to pass that cost on to other ratepayers. Their bit problem, and biggest cost, is servicing summer peak hours around sunset. Help solve their problem you deserve to be rewarded, make it worse and you should pay.I hate you SRP.
I'm confused. How does adding a 2 ton unit save money?Given that the LION'S share of our consumption is the 5 ton A/C, I could save way more than that and have a very speedy payback period by getting the EG4 2 ton mini-split and mounting the panels I already have as a rear porch pergola.
Ah, thanks. I was thinking about demand charges, but you're on TOU with no demand charges.
So basically buying the 2 ton instead of an inverter to feed the 5 ton. And avoiding inverter losses while you're at it. Interesting.
I used to turn my A/Cs off when ERCOT called for peak shaving from 3-7pm. The house would gain about 1 degree F per hour in full sun and 100 degrees. I never measured after sunset, but heat gain would be much less. I bet if I pre-cooled the house directly from solar then just shut the A/Cs off when the sun got low it'd be 3-4 hours after sunset before they needed to fire back up on grid power.
My house has a lot of thermal mass, though. I wonder what it'd take to build all new homes with enough thermal mass to avoid summer evening A/C? Or maybe even retrofit old ones. Thermal mass has other benefits, too, e.g. no climate control needed at all in spring and fall, especially with open windows at night. If I had passive solar I could probably avoid heat 90% of the winter, too.
Series connected air conditioners2) potentially feed cooler air into the intake of the 5 ton - the intake register is favorably located for this, i.e., the great room is adjacent the intake register - use the 5 ton's blower to distribute the cooler air through the house.
I had that in CA, but temps were never extreme so it was not an issue. Here in TX I have brick exterior, huge slab, radiant barrier in the roof, white "Polywood" shutters, etc. Plus it's a big, squarish two story so volume-to-surface area ratio is favorable.2x4 stick built with stucco. Not much thermal mass at all.
