ptc53
I converted to a EG4 12V 400AH battery (w/520W Solar) last summer. I changed over the setting on my solar charge controller and trailer converter-charger to lithium battery setting and I added a Victron Smart Shunt. The battery is mounted in the front crossover area in the trailer and I ran the battery cables (2/0) to the junction box under the trailer (Outdoor RV 24RKS 2022) to bus bars for distribution. All of the cables/wires that had been connected to the old lead acid batteries were moved to the bus bars.
The battery charges to +14.63V using the panels according to the Smart Shunt. When the Smart Shunt says the battery is at 83% the voltage drops to 11.83V.
Everything seems to work find e.g. I can start my onboard genset, etc. But if we are watching TV and the furnace kicks on the TV turns off. Once the furnace is up and running (2-3 minutes) I can turn the TV back on and it works fine.
Do I have a battery problem? Or could it be something else, e.g. I solder the lugs on the cable (I just ordered a crimper), etc?
Thanks
Thanks
