Should be straightfoward. Be sure to look up your exact inverter model on the ena type test register and use the ena reference on the form.
ENA Type Test Register
www.ena-eng.org
maybe this one?
https://www.ena-eng.org/gen-ttr/Index?Action=ViewDetail&EID=66519747&tab=search
You have an uncanny knack of answering my questions - in this case, the one I didn't know I needed to ask!
I spoke to my DNO - Northern Powergrid - a few weeks back., They asked me to fill out a huge, complicated form, I honestly didn't understand most of the terminology it (in hindsight, it's probably for large-scale generation). I've not progressed as I was unsure how to proceed, but looking again today, I found
another page on their site that splits out the G99 and it's fast-track options. Until finding this, I've heard of forms from other DNOs that are similar, but it now seems that although G99 and fasttrack G99's are common accross the DNO's, they're named/numbered differently by each.
So, I now have the right form, the information I need to fill it out, and some confidence that this is moving in the right direction. Slower than planned, but life always gets in the way. This time it will be a job for this evening but it might actually get completed ?
In the meantime, I've put together a diagram of how I currently think this will all go together (high level - no detail yet). Really, I'm trying to work out where how to prevent exporting to grid, but still allow the inverter to send the excess to the Zappi to consume any excess production. Both the inverter and Zappi expect to monitor the feed with a CT clamp (labelled 'CT' and 'Grid CT') for energy flowing to the grid. If there is, the Zappi should take that energy, to charge my EV. However, the Inverter sees that and stops the export or at least reduces it to 16A, to remain G100 compliant). I'm not sure if I can put the CT clamps in another position or change the architecture to stop this being an issue. Any input would be really appreciated.
What I want, is to prioritise the solar consumption like this:
- Normal loads (the big DB)
- Top up the home battery
- Charge the car (Zappi - only consumes the excess that would otherwise go to grid)
