solartist
I am a homeowner at the design phase of renovating my 1930s terraced house in England, and I want to incorporate solar energy into the plans.
I would appreciate your help at this early stage. It's "cheaper to make mistakes on paper" (cf. Sofie Pelsmakers), and I might need a few design iterations to get this right!
After wrestling with some questions for weeks, I decided to summarise my situation and post here. I hope with your help I can achieve a plan that is affordable, safe, legal, and efficient.
Questions:
Background:
Desiderata:
Sub-threads:
I know this is a lot to digest. I'm grateful to anyone who reads this far and offers constructive suggestions! Thank you!
If I think of any more desiderata/questions/clarifications, I'll update this post.
Questions:
- Which makes/models of inverter/micro-inverter/optimiser/charge-controller/gateway/battery/AIO/BMS/etc should I be looking at, to meet the desiderata below? (Tesla Powerwall 2 + Tesla Gateway combo seems to meet most of the desiderata - but can it be used without proprietary apps/cloud? If it can't be, then where else should I be looking? Victron? Something else?)
- Are smart sockets reliable enough that I wouldn't need to run extra wires to each room for essential vs non-essential loads? (See discussion in "Desiderata" below.)
- In the desiderata list below, I flagged some points where I am unclear on the terminology/jargon. Have I used the right terms?
Background:
- Grid is single-phase 230V AC nominal @ 50Hz. I would upgrade to a 3-phase supply if that would reduce overall cost.
- House is 4.6m wide, 6m deep, with a pitched roof. It has a 30m long back garden. The front of the house faces west-north-west.
- Skylights will occupy approx 2m² of front pitch, and 1m² of rear pitch.
- Neighbour has a tall, narrow chimney whose shadow moves across roof during day. String inverters are therefore probably not ideal.
- I want to do as much planning as possible before I contact a licensed electrician/installer. This way, I'll know if any suggestions they make are constructive.
- Retrofit will hopefully include:
- insulation/airtightness to Passivhaus enerPHit standard, or close.
- MVHR.
- air-source heat pump (mini-split) for space heating/cooling.
- replacing the gas boiler with a fossil-free alternative for hot water.
- Loads will include:
- domestic needs of 2 adult residents (with high laundry requirements for medical reasons) + occasional guests.
- HVAC as above (MVHR/space-heating/water-heating).
- servers & networking equipment consuming ~1kW on average.
- Predicted essential loads (lighting, computing, fridge/freezer, microwave): 2kW peak, 16kWh/day mean.
- Predicted non-essential loads (including electric car, if I get one): 12kW peak, 26kWh/day mean.
Desiderata:
- Meets Permitted Development rules.
- Once commissioned, can be controlled & monitored using free as in freedom (aka Open Source, aka FOSS) software only.
- OK: emonPi, iotaWatt, Home Assistant, and similar control/monitoring systems; physical control panels on the wall (if not "cloud"-connected).
- NOT OK: proprietary smartphone or cloud apps.
- Grid-tied, so:
- excess daytime solar (if any) can go to grid instead of being wasted
- cheap night-time grid energy can be used to charge the batteries for daytime use (crucial on cloudy winter days)
- Grid-supported (is that the right term?), so when loads exceed solar & battery capacity combined, grid will supply the shortfall.
- Automatic UPS functionality, so essential loads are seamlessly switched to solar and/or battery power if grid goes down (power outage). (Is "hybrid" the term for this?)
- Automatic anti-islanding: disconnects from the grid if grid goes down (power outage).
- Automatic recovery from anti-islanding when grid comes back up. (Is "automatic reclosing" the term for this?)
- Capable of gradual installation (in stages/phases) e.g.:
- Home rewiring first (during interior renovations) to:
- Put consumer unit in sensible location.
- Install additional mains wiring/sockets circuits so essential loads can be automatically separated from other loads (see earlier) - each room would have some "essential load" sockets and some "inessential loads" sockets. (Alternatively, are there smart sockets that are trustworthy enough for this task, so that separate circuits would not be necessary?)
- Lay conduit in walls/floors/roof for additional cabling (48V DC?) that might be needed later.
- Install inverter(s) & anti-islanding device(s) when funds allow.
- Install panels on roof when funds allow.
- Install 1st battery bank when funds allow.
- Install panels (or solar brise-soleils) on rear wall of house when funds allow.
- Install 2nd battery bank when funds allow.
- Install panels on outbuilding when funds allow.
- Install 3rd battery bank when funds allow.
- Install panels on garden wall when funds allow.
- When complete (see above), can power essential loads for 24h in case of power outages.
- Sourced from UK retailers.
- Long parts/systems design-lives/warranties preferred (≥10yrs, ideally), even if this means only charging at 0.5C.
- Batteries should be capable of being safely charged at 0.5C irrespective of ambient temperatures, even if this means adding heating/cooling/insulation to keep them at ~25°C or whatever is optimal for their chemistry. (Ambient temperatures fluctuate from about -10°C in winter to almost 40°C in summer.)
- As inexpensive as possible, even if that means e.g.:
- DIY such as assembling batteries using prismatic LiFePO4 cells from Fogstar/similar.
- AC-coupled panels & batteries, if that would cost less than running 48V DC wiring.
- Edit: carbon neutral once renovations & solar complete.
Sub-threads:
- [UK] Are there any G98/G99-compliant "cloud"-free microinverters?
- [UK] Consumer units with affordable SPDs, AFDDs, and Type B RCDs/RCBOs?
- KNX home automation: is there a FOSS (Free and Open-Source Software) alternative to ETS?
