Hello guys,
I am in the process of planning an upgrade to our electrical system on our sailboat. We live aboard 24/7/365 at anchor - therefor a reliable system is very important to us.
I wanted to run my thoughts by you to check if my plan makes sense and ask for your suggestions. I would very much appreciate your feedback. There is a lot of knowledge here!
Our current system looks like this:
As you can see there is no separate starter battery but all loads are powered from the same 2 lead acid batteries.
We would like to upgrade the system to power a bigger inverter in order to run a small washing machine and an induction stove top (we have gas as a backup).
A simple system could look like this (green is our planned upgrades):
As you can see we have replaced the batteries with 4 Battleborns, added a bigger inverter and the additional consumers. I would add an alternator protector between the alternator and the battery bank to safeguard the alternator in case the Battleborn BMS cuts its charging input. More solar is added as well to compensate for the additional consumers.
This solution would be the simplest to implement since it is basically the same as our current system. An alternative would be to separate the power bank into a house and and engine battery bank:
The advantage I see is that the alternator won't be overused due to the draw of the Lithium batteries (draw is limited by B2B charger) and we would have a backup to start the engine in case the house bank is empty (this has never happened so far). The downside is that it will require a significant amount of work to rewire everything which I would like to avoid if necessary. I tend to go for the simpler solution.
Having explained our setup and plans I would ask you for your feedback on:
Patrick
SV Falkor 4.2
- Does our planned upgrade make sense? Do you see potential problems or gaps? (Given that the overall power consumption is in balance with the production)
- Do you think we can get away with the simple setup (no extra starter batteries). Will the starter draw be a problem for the Battleborns?
- I assume I would have to limit somehow the current draw from the alternator in order to now blow it. What would be the easiest way? External relulator or is there another simpler solution?
- Do you see any other downside of the simple setup?
Patrick
SV Falkor 4.2
