Vigo
The problem is the controller doesn't know anything until AFTER the first 'pulse', and if there is very much voltage difference between input and output, and the input is a battery capable of supplying hundreds, perhaps into the 1000a range, that first pulse = you let the smoke out. I've verified this personally..lolWhy, it would just adjust the duty cycle to limit the current the charger can handle.
If you think about a 12v typical car battery, hooked up to something with 12 less volts.. almost a dead short.. lots of them will touch 1000a in that scenario. Some bigger ones will do 2000, some bigger AGM claim 3000+a. How many microseconds of that does it take to flash boil the metal in the transistor trying to flow that current? One. 1 microsecond. 36v into 24v, same deal, doesn't matter. You've got a source with huge ampacity hooked to something with much lower volts and very low resistance in the circuit = instant excitement.
It can be made to work with much finicky bs. It would be easier to skip the bs and buy an mppt controller with current limit settings, as they 'ramp up' versus simply shorting the input to the output.
