I have a 12 volt system for my camper.
440 Amp hrs of LFP battery, and 800 Watts of panels.
I Installed a 120 volt charger as well, and have charged to 100% several times in the last couple months, and discharged down to 150 Amp hours as the lowest discharge, and several other levels, but higher. This is only with the 120 charger, not solar.
Parked the camper in the sun today and the Victron 150/85 says I harvested 1250 Watts/104 Amp hours, but my battery monitor claims I have added 158 Amp hours.
I started with 221 AH. and ended with 379 AH. over roughly 8 hours. I have had nothing but the LP detector on. No other power draw.
As an aside, my 800 Watts of panel, laid more or less flat produced a peak of 502 Watts. 62% seems a touch low, but it is just early April...?
Any suggestions or can you point me to instructions on how to learn if it is my monitor, or SCC that needs adjustment?
