Robbert
I would like to program and use the dry contacts in my new JK-inverter BMS.
The purpose of this is to control a relay that switches AC-power-in to the inverter to 'ON' if the battery gets below a certain SOC.
That way the inverter is disconnected most of the time from the grid and only has AC power at the moment required.
Some relays use a low DC control voltage, while others accept 240v AC as control voltage.
In the dry contacts only miliamps will be flowing, since it is only to control the relay. Is it safe to do this with 240 volts?
