NCislander
I am using a DC Power Supply (Wanptek KPS 100v/10amp) unit.
Fuse is located in the 120vac input plug assembly. Unit states to use a 250v rated fuse, no ampherage rating for replacement.
The fuse is blown, writing on its description Un-Readable.
Do any users out here have ANY Wanptek KPS DC Power Supply? One you could look at your fuse rating, what you have installed?
Wanptek documentation does not give fuse amp rating, only voltage (250v fuse)
-Thanks for any help.
