I’m running the JK B2A20S-20P’s and now I’m about to commission #3. The previous two are mounted large flat side toward the vertical mounting surface (wood) with 3/8” spacers so that convection cooling can occur. The thing is now if I can do the same thing except flip it bump side with spacers to the mounting surface, my battery cables run will be be about the same as the other two batteries(no double back). Just wondering what side of the JK gets the hottest (both?)from the MOSFETs or does the top need to be the coolest? Or am I overthinking it?
