Our system will be a 13.2 KW grid tie, using a Fronius 11.4 Inverter. The panels will be mounted on a shed. The AC 220v run from the Inverter to the distribution box will be 275 feet (100' inside the shed, then another 175 feet underground to dist. box). This will be Aluminum wiring
I know this is quite far, but doable. I'm having problems calculating the gauge of wire needed. Help requested!!! Thanks
