uksuntimes
This was solved thanks to everyone's help. Details and items are in all the posts below for anyone else that might arrive here one day
ORIGINAL MESSAGE
Hey everyone!
I am struggling to know what to search for and would love a little guidance as I suspect there is a special type of name involved
I can find lots of relays (e.g. voltage sensing relays) that will turn things ON when they are sent a 12v ignition signal, but in my case I want to turn things OFF while the ignition is live, and turn back on when the ignition is gone.
Might there be a different kind of relay or device I can use to do this?
My use case is as follows
My reason for this is that I can get a full 50A charge from my alternator while driving but only if the solar is disconnected. At the moment I manually flip the breaker, but I would like to automate this instead so I can get full charging juice while driving.
I will keep searching around, but so far everything I am finding is about connecting when 12v is detected, but not disconnecting.
Thank you all in advance!
ORIGINAL MESSAGE
Hey everyone!
- I have 2 x 170w solar panels, connected in parallel
- I have a smart alternator
- Both of these go into the 50A Renogy MPPT smart controller (yes yes, I NOW know about Renogy, but it's what I have).
- When I have the car running/alternator signal ON, I want to DISCONNECT the solar/PV input. When the car ignition goes off again, I want to RECONNECT the solar/pv input
