Do you know that the MPPT will behave in a manner that will yield those results?
I know how a properly designed MPPT for an SCC should function.
If you want to broaden the discussion to include SCCs/MPPTs that may not have been designed correctly, that’s not a discussion I’m interested in (nor one I feel the least bit qualified to participate in).
What algorithm does it follow below 120V?
It can’t go below Vmppt_min, that’s why it is the
minimum voltage of the MPPT…
What algorithm does it follow above 120V?
A properly designed MPPT allows voltage to increase above Vmppt_min until power decreases.
The only real ‘algorithmic’ part of the entire affair is when the controller decides to search for higher power levels by allowing bypass diodes to activate. It does this by occasionally pulling string voltage back down to Vmppt_min (or some other lower voltage above Vmppt_min) and letting voltage increase to a new maximum power point.
No. I didn't mean this at all. I meant what if it just performed like shit?
As Vmppt_min increases further and further above Vmp and closer and closer to Voc, performance suffers more and more, from near-optimal to sh*t.
My response was to this question:
I indicated I would assume the worst, i.e., stop operating without confirmation otherwise.
A properly designed SCC MPPT will not stop operating when Vmppt_min is greater than Vmp of the string. Full stop.
Checking with a manufacturer for confirmation is never a bad idea.
But if they state anything to the contrary it means they did not design a proper SCC MPPT.
Nor did you mention damage:
I see you are correct that the OP was not explicitly asking about potential damage, so I apologize if I misinterpreted your response from that confusion on my part.
I thought the context was pretty clear.
I assume you are referring to the context you outline below. If you meant something else, thanks to clarify.
I'm assuming this is cheap Chinese shit where across all brands and models erratic behavior and low overall quality is well documented.
Could be, but since the OP stated nothing to that effect, I’m not sure that assumption adds to the discussion.
More to the point, poor quality of some cheap Chinese inverters is one thing but has nothing to do with how an SCC MPPT is supposed to function.
The only way an SCC MPPT will not function properly when Vmppt_min is greater Vmp of the string is because the SCC MPPT was improperly designed (which again, is a ‘context’ I don’t feel qualified to connect on)
I'm not assuming anything but the worst about them unless I get a guarantee from the distributor/manufacturer
You are allowed to assume anything you want, but I assume we’ve both engaged with this thread from a desire to assist the OP - isn’t it the OPs assumptions that should be important to the discussion rather than yours?
, and I'm not going to give anyone the impression that it may perform acceptably unless I KNOW otherwise.
And you are totally entitled to that position.
My position is that I can contribute the most by clarifying how a properly-designed SCC MPPT is intended to function,
A properly-designed SCC MPPT has no problem functioning properly when Vmppt-min is slightly higher than Vmp of the input string, certainly when we are talking about Vmppt_min of a few volts higher / < 10% higher than Vmp of the string and only on the case that output in the presence of partial shading is not a priority.
