Did you ever get one to check out? I am thinking about this one for the low temp protection. Thanks!I'd bet money that it is garbage on the inside. I'll have to rip one open. That is dirt cheap.
I have a low temperature shutoff on my solar charger
I brew a lot of beer and wine in 6 gallon carboys. We are talking A HUGE amount of thermal mass. Temperatures must be within a degree or two for controlled fermentation so I bought a thermal well to accurately read the actual inside temperature with the remote fermentation probe. Then I tried an experiment where I taped a probe to the outside, then covered that with an insulation pad. Guess what? It was within 1 degree of the inside measurement.I have concern of relying on the charge controller low temp shut off......The battery freezes at night....next morning the charge controller warms up before the cells do and starts charging still frozen cells......Even if there is some type of remote temp probe that you place on the battery case, the cells could still be frozen when the outside of the case reports "safe to charge"....
Interesting. I think mine went up to somewhere around 14.2 to 14.4 ish?I was In the middle of testing them, but an unrelated, more urgent problem came up.
I charged them up with an older, supposedly Lithium compatible charger. Not 100% sure, but I think the BMS blocked current once 13.44 volts was achieved on one, and 13.31 on the other. These voltages held after rest. I was hoping to see the BMS go into balance mode.
Once I got my solar controller working they went up the same. My controller then drops to a 13.6 float, so if I’m not watching I can miss it. I also discharged with 1400 watt continuous actual load(convection microwave) on a 2200 watt inverter and it worked fine. This was two in parallel, so I’m satisfied. Haven’t tested where the BMS’s will cut off, but they likely meet spec.Interesting. I think mine went up to somewhere around 14.2 to 14.4 ish?
Any ETA for a teardown video of this battery? The old adage "If it seems to good to be true..." has me worried but I am sorely tempted.I'd bet money that it is garbage on the inside. I'll have to rip one open. That is dirt cheap.
That one only has a 100aH BMS. Fine for most applications, but not for larger inverters. Seems like it’s tough to get everything in a low cost battery. Getting better, though.vestwoods was selling their 200ah battery for 609 with low temp cutoff. last I looked they bumped up to 690
but if you watch they may drop it down again, as that happened several times while I was looking over a course of few weeks.
Does low temp actually work? I don't know .
BTW, I just checked - that battery is currently unavailable.
