6" Swivel Casters $3.25
42OhmsPA
What's in a title?
Pennsylvania
Found this on garage journal, thought it would be useful here.
Build a mobile cart, make your battery rack portable, make a portable array, possibilities are endless.
Free shipping over $50.
In for a dozen plus some stuff I don't really need but will use at some point.
The swivel bearing can be greased for smooth wheeling.
SPECIFICATIONS:
Type: 6" Swivel
Capacity: 440 lbs.
Mounting plate dimensions: 4.49" x 3.94"
Distance between holes: 3.46" x 2.95"
Height to mounting plate: 7.48"
Good weight rating. 16 for me.
There has to be a reason they are clearing them for so cheap, my guess is the rubber will flatten with long-term load and you will end up with what they call in the train world a wheel flat.
Mine showed up this weekend. BEEFY units.
I see the price doubled...get them if you need them.
Thanks again for the heads up!
