Beeralph
In 2010 I purchased a 20 year lease on a 6kw home grid tied solar system from Solar City. They were owned by Tesla, but pretty much operated independently. It came with a warranty for the life of the lease for equipment failure and labor included to repair or replace such equipment. They also promised in the event of roof replacement due to acts of God, they would remove and replace the panels.
At first they were great. I had a panel that the glass shattered on and they came out and replaced it while I was at work, no charge. I ended up recommending them to at least 4 people I knew who took a contract with them.
I ended up having to replace my roof due to hail damage about five years ago. By this time Tesla had taken over. They couldn't get a crew out for almost a year. They told me I could contract with a licensed installer and the warranty would still stand. I hired a local company who did a great job.
2 years ago there was another bad hailstorm and once again I was forced to use the same contractor as before. Once again they did a great job. 18 months after that the inverter stated failing. I called Tesla and they scheduled a tech for a month out. Of course by the time he got there, the inverter started working again. This happened twice more before the inverter finally failed while the tech was there.
He replaced the Fronius IG5 inverter with a Tesla one. He installed it just as the sun was setting. I saw that the inverter was producing about 500 watts and assumed it would get back to normal levels when the sun came up. It never did. The same tech had told me on a previous visit when my inverter was working intermittently that Tesla's inverter was much more efficient, but it was possible that the panels might need to use a different string configuration. When I contacted Tesla I told them that and they acted like I was crazy or stupid. That inverter was put in in late October 2023, and I just now got it working right. I looked inside the inverter panel and realized that with 35 panels on my roof, the only way this inverter would work was to run 4 independent strings. I contacted Tesla and sent them pictures of the installation(5 strings of 7 panels in series connected in parallel at the junction box with 1 positive and 1 negative running to the inverter) . I told Tesla that the diagrams inside the inverter specifically said that if the B terminals on the inverter were used, the strings must have an equal number of panels. They said they would get back to me. When they did they said the problem was due to a third party installation. They wanted $5700 to remove the entire system and reinstall it. I complained to the BBB and they kept stalling. Finally they quit responding to me and the BBB and got an unresolved complaint.
I knew the wiring was wrong. Yesterday I wired the panels in accordance with the independent string diagram on the inverter. I had to remove 5 panels to access the strings and tie the panels in 4 series strings with 9 panels on three strings and 8 panels on one. I removed the gage 4 wires from the conduit and used them to pull 8 10 gage wires through. Today instead of making less than a kilowatt of power, I am making almost 6. I doubt I will say anything to Tesla because I just don't trust them. I regret taking a contract with them and recommending them to friends.
When this contract is over I will probably install my own system. It is terrible when you pay for a warranty that is worthless. I hate being lied to. Things like this give the solar industry a bad name.
