Thanks Jared! I was just wondering about open loop. However, I have 6 EG4 Lifepower4 batteries with rack and an EG4 communications hub. I was told a year ago by signature solar to set the voltage in the hub to 56.5 for closed loop. Setting the value in the hub to 56.5 changes the following settings in my inverter: float voltage, absorption voltage, and equalization voltage all to 56.5. Say I change it to 56.2, it will change all three of those settings to 56.2. There's nothing I can do about that. Do you have any insight on this?
