Capt Bill
Sailing Options
Wow: That is interesting to me as guy with a couple of LV2424s to hook up and dial in (upcoming project).With my lv2424 the absorption does happen very quickly. Now tictag says that the bulk phase of charging should be constant current but if I set my SCC to 50 amps max charging and I only have solar power (1380 watt array nominal) the current does not remain constant during the bulk phase. If I’m lucky my battery will achieve the bulk voltage I have on setting 26. Then the float voltage (setting27) will be maintained but my lv2424 display never shows 5/5 bars (full charge). Now I’ve barely ever charged from the grid but I did this week. I set my max utility charging amps (setting 11) at 20 amps. It charged exactly as it should. Constant current until absorption voltage. Then a quick absorption. Then float. And the display showed 5/5 bars or full charge. I don’t know how to explain it, but I wonder if it wouldn’t work for OP.
For posters with less than ideal solar panel battery charge: I wonder how your solar panels are set up going into the LV2424 ? and ... I wonder if different PV configurations could make the MPPT Solar Panel to Batteries charging rate act differently ?
If this is not a configuration at LV2424 challenge to dial in with internal adjustments; I wonder:
How are is your Solar Input configured? and if different PV could produce different or contrasting battery charging results (do not know why it would, but wondering).
Here's my references for this question; which kind of present a side question for the LV2424:
Re: My Efforts to eventually get 240v split phase: I will start with one unit, then add 2nd:
PV . Solar Panel Configuration Question: I obtained 6 x 345 watt solar input (for each of my LV2424s); w specs: 345 watts each / Open Circuit Voltage: 46.59 vdc/ Voltage at MPP 37.93 vdc /Current at MPP 9.10 amps:
against Specs / Max. PV Array Open Circuit Voltage: 145Vdc /and PV Array MPPT Voltage Range: 30~115Vdc
(and No max current spec)
Two Options for my PV array configuration:
I could Parallel two sets of 3 solar panels wired in series for max volts & less amps /my PV Panel specs x 3 = Voltage at MPP = 113.79Vdc / & Open Circuit Voltage = 139.77 ... just under max LV2424 PV specs) !!! (for about 115 vdc /@ max 18.3 amps )
OR:
I could Parallel three sets of 2 PV panels hooked in series that would be less volts @ higher amps (about 78 volts / 27 amps) ???
I have asked: IS the Higher voltage just under Spec limits of LV2424 most likely better / + makes better use of wire size ... from your point of view?
I have a contrast of feedback from experienced solar folks: like a master Solar buddy who says for MPPT: "Voltage is King / always go with higher voltage/ and from some individuals this forum: also ssaying: go with higher voltage/ make better use of your wire sizes.
In contrast to USA-MPP-SOLAR / Ian's feedback to my question: I would not put more than 2 in series, as 3'x 38V is cutting it fine to the limit. 2s3p. And 47V x3 is too close to the max 145V for my liking.
Note: The lower voltage feedback matched my original thoughts/ as that is closer to the 24+V LiFePO4 battery bank I will set up. I might test both ways at some later date.
Food for diagnostic thoughts? What is your PV solar input/ how is configured/ Could that make MPPT to Battery charge profile shift a bit?
