Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,047
Sed linked to an ASI breaker on homedepot.com, but they sell directly, and have DC breakers rated at 125vdc/pole. Using a two-pole breaker on positive and negative, according to the datasheet, would give up to 250vdc. Here's an example, a two-pole 50A breaker at 250vdc:
Electronic Components & Supply Online Store | ASI
Need automation components and parts? Check out ASI's vast inventory of electronic components for automation and industrial applications.www.asi-ez.com
Quite a difference between 250vdc and 400vdc, but 250vdc isn't nothing.
My initial system 15 years ago had 24, 12V panels in series with and Outback box that had 6 or seven 15A 150V breakers. Those segmented the 600V string to groups less than 100V each. That was before MC connectors that let me safely mate a high voltage string.
Later I used unfused 30A 600V "heavy duty" visible blade disconnects.
Now I have touch-safe fuse holders for multiple 600V strings, and the inverter has a DC disconnect attached.
