Hello to everyone and thanks to this forum for existing. .
I have two 100watt solar panels connected in parallel
Then at the end of connector I have another parallel connector in sense splitting the input into two.
First: is this safe to connect to 2 solar generators that are similar in solar input? Or will this throw off something by wiring it like this?.
Secondly: how will this affect the charging? Is it safe to assume the power is equally spit or is feed to the each side as needed. For example, Two solar generators hooked up, both charging at same rate? Then once 1 is fully charged will all that solar input be put into the other bank or still only half?
Sorry for confusing questions. And thanks in advance. I can provide more info if needed.
Fatboy
Fatboy
