I am a huge proponent of LTO batteries because of their -30C capabilities and their fast charge rate. However I'm am not a fan of 10s configuration simply because it does not produce enough volts wher the majority of the energy is output. So if you are going to buy these I recommend planning on breaking these things apart and going 12s for 24 volts.
069CGA2064061J93T0003572
Volts - AH
2.6 - 0.0931
2.5 - 1.3818
2.4 - 4.3402
2.3 - 5.4748
2.2 - 7.1848
2.1 - 15.0611
2.0 - 7.9945
1.9 - 1.2032
1.8 - 0.3092
1.7 - 0.1181
1.6 - 0.0851
Total 43.2459
The above for example is the discharge log of a 66160 LTO cell
if you notice the majority of the energy is produced at around 2.1 volts so 10S will only output 21 volts .
my test is drawing a mere 10 amps from the cell if you went to 40 or 50 it would be even lower which most likely will shut down inverter.
for myself Im actually considering a 25s 48V system so that the majority of power is at 52.5 volts and stopping charge at 2.5 volts since not much is yielded above that range.
