In a 24V system, with a Victro MPPT 150V-60A, and 6 195W panels (see specs below), would you recommend having 3 panels in series and 2 parallel OR 2 in series and 3 parallel OR something else?
I read in other posts that I should make sure to multiple the VOC*1.25 (I live in Canada) and make sure is below my MPPT 150V, So even if I use 3S2P the total VOC is 67.23*1.25 = 84V and 19.74A way below the 150V 60A. Also, I learnt that Higher voltage = Less Drop & the possibility to use smaller AWG. So unless I missing something like an unbalanced configuration, or the possibility of shade in some of the panels creating an issue, etc. My guess is this is the best configuration. I never done this before, All the help and advice are more than welcome!! Thank you!!
The Solar Powers Specs:
SOLAR - 6X Eco-Worthy 195W 12V Monocrystalline
MPPT - Victron Energy SmartSolar MPPT Tr 150-Volt 60 amp Solar Charge Controller
WIND - Eco-Worthy 400W Wind Turbine
PWM - Eco-Worthy 20A (For Wind Turbine)
BATTERIES - 4X FlyPower LifePo4 Battery 12v 240Ah
INVERTER - SunGoldPower 24V 6000W (18000W Peak) Pure Sine Wave Split Phase Power Inverter with Charger 60A
BATTERY-BATTERY - Sterling Power - 12V to 24V 70A Pro Batt Ultra
DC-DC - Victron Energy Orion IP20 24/12-Volt 70 amp DC-DC Converter Non-Isolated, High Power
BATTERY SHUNT - Victron BMV-712 Battery Monitor
BUSBAR With Mega Fuses - Victron Lynx Power-in [LYN020102000]
0/4 AWG and 2 AWG Wires
- Rated power: 195W
- Voc: 22.41V
- Vop: 17.9V
- Short circuit current (Isc): 9.87A
- Working current (Iop): 8.89A
- Output Tolerance: ±3%
