dudeinthewoods
- Apr 7, 2020
- 111
I've got a 48v LiFePo4 battery bank working fine.
At the moment the BMS (which is accurate) shows 46.3v
The inverter and SCC is showing 10v higher at 56.6v when I hit the breaker on the scc the inverter reads ~ the same as the battery.
I wouldn't care about the numbers but
1) I want to understand why
2) It stops the battery from charging early
3) the invert trips from over voltage
It's probably something simple. I've got the inverter, battery and SCC all coming together on a bus bar. Do I need to wire it differently?
Thanks!
Thanks!
