I have just completed the installation of solar panels on my boat. One on each side... There is a hole through each side of the boat from the factory the just barely fits an MC4 connector. It's approximately 20mm diameter. The problem is once I get one connector through the second one won't fit with the wire from the first alongside it. The boat is used seasonally (Minnesota) and I need to remove the panels when taking the boat out of the water each fall, so I need to be able to disconnect and reconnect in the fall/spring. The connection is in a covered, but open from the side, compartment under a seat in the sailboat cockpit. The best option I've found so far is 45amp Anderson Powerpoles. Is there anything else I should be looking at? I'd prefer waterproof if an option exists that will fit through a 20mm opening. Each side is a single 100w panel with 10ga wiring (Ancor tinned copper). Thanks, Chris
