Samsonite801
Solar Wizard
- Oct 15, 2020
- 2,994
10 to 12 kW of 240VAC is what we need for the two servers. This is not a typo. We have a generator so the 18KPV only needs to last long enough for it to start. If we had APC UPS as you suggest then we wouldn't need the 18KPV! If the 18KPV is not suitable as a UPS for a server then it shouldn't be marketed as one. Many users might be having power quality problems during the 18KPV switch-over and not know it. Or maybe it is only us due to this one unit, our configuration or something else we are doing wrong. This is why I am asking for feedback from 18KPV users. Would also like to hear from Sol-Ark users if they are powering sensitive critical loads like computers as maybe they work better/different. The Sol-Ark does quote a 5ms switch over vs 10ms EG4. I wonder if one number is too simplistic for this spec. Is there actually a "curve" involved where it takes time to ramp up the inverter and this spec should either show this curve or provide a couple of data points to show current availability vs time. Total speculation on my part here.
You could always consider configuring your 18k to work like an 'On-line' UPS, which would be where you leave the 18k to run only on battery all the time, and buy enough standalone DC chargers (for example the EG4 Chargeverters), where the generator (or grid) can just keep the batteries charged 100% of the time via the standalone chargers. Then there is no switchover from the server rack's perspective.
Just install an ATS upstream of the standalone battery chargers, to automatically switch between the grid and generator power.
I might rather do that anyways, since the standalone chargers can tolerate a wider range of input frequency in case the generator frequency is not held perfect for some reason, the 18k inverter/charger would reject the power, where the standalone charger would keep going.
Chargeverter advertises an input frequency of 50-60Hz. I have 4 AIMS 18.75a chargers which advertise input frequency tolerance of 40-70Hz, so something like those can take dirty power all day and still charge batteries like normal, business as usual, even if the generator governor is failing to hold RPM steady.
Just a thought anyways.
