Samsonite801
Solar Wizard
- Oct 15, 2020
- 2,994
Yup, it'll work fine as a string disconnect, as shown in OP's post or rewired to open both positive and negative leads. Two 150V poles in series, ganged to trip together, will interrupt current the same no matter where each one is in the circuit (so long as in series with the circuit including a fault they might be interrupting.)
When three or more strings are in parallel, I don't believe multiple separate polarized breakers can be relied on. The PV string that is shorted and being backfed trips, but won't interrupt the arc because current is flowing in wrong direction. Ganged with the other two breakers I think it would work. (not the OP's situation.)
Yeah, earlier I had wanted to say I thought it was Hedges who had been the, said: 'reputable poster', who I had thought I heard this confirmation from in another post before, so I had been waiting to see if he would chime in, since I didn't want to accidentally try and drag someone under the bus.
Anyways, thanks for backing my remembrance of that, it does make perfect sense...
