Continuing to think things through... I emailed Jason. He said about consumption and procedure when I'm parked in storage and shut down (no shore power):
"in sleep mode, the lcd back light is off, relay controller is disable. BMS still detect cell voltage. and draw current from battery, it is around 5mA, depends on battery voltage. temperature and so on.
if battery storage over 1 months even 3 months, power off BMS and disconnect battery balance wire is suggested. and make the each cell voltage is in storage voltage, and charge or discharge once time every 3 months. to do so can avoid battery discharge and capacity loss."
@ 5mA consumption, I'd lose 3.6Ah / month to the BMS. Or 43.2 / year.
Then again, Grizz's numbers, above are 6 times that consumption!!
The most I'd ever leave the camper without use is 3 months. And that is rare. Usually once / month.
I'm planning on installing the battery in an accessible location, but one where it'd be inconvenient to disconnect the BMS.
1. Do I have a risk if I charge / discharge to say 50% to 60% SOC (280Ah) and leave it without disconnecting the BMS?
2. Does the BMS run off of just one battery pack? If so, they'd all be out of balance substantially after a 1 or 2 month hibernation.
