Thanks, I couldn't remember the "name".I never did get around to building one but others seem pleased and @upnorthandpersonal provided loads of excellent info.
DIY 'Chargenectifier'
Based of the informative info recently posted by @ChrisFullPower in another thread I'm intrigued in DIY'ing a charger from used rectifiers. A quick search on eBay for '48v rectifier' has made me realize it's definitely doable at costs much lower than off the shelf options... I'll start with a...diysolarforum.com
why would you go through all the hassle? Just purchase another AIO inverter, and feed it generator or whatever power your going to feed to the chargeverter, then you have a backup inverter in case you need one. this basically just uses an AIO inveter as a charger only. don't hook it up to loads if you don't want to.
I'd buy this for this exact purpose:
EG4 6000XP Off-Grid Inverter | 8000W PV Input | 6000W Output | 480V VOC Input | 48V 120/240V Split Phase | All-In-One Solar Inverter
The EG4 6000XP is a cutting-edge 48V split-phase, off-grid inverter and charger, designed to revolutionize your energy needs. With an impressive 8kW of PV input capacity and an efficient 6kW continuous power output, it also serves as a battery 140A charger. What sets it apart is its scalability...signaturesolar.com
you can see how I did something similar in my video siggy
This is fair enough!Strictly to avoid my money ending up in a showalter pocket.
No scientific or rational reason, I will admit ?
For sure. The specific inverter you linked though, the brightmount, and chargeverter make it a mighty challenge to stick to my nonsensical principles ?This is fair enough!
I just always try to think redundancy as i'm electrically off grid, more backups are always better :D
To be honest 2 of those inverters with a 3rd in a box as a spare would be “chefs kiss”
I have 2-champion 5500w inverter generators and 1 split phase capable 10kw champion inverter generator.It would be interesting to see the exact use cases someone is envisioning ...
I always like the idea of a 2nd inverter "spare" on the shelf ... nothing wrong with that at all, given the fragility of these HF inverters ...
This was my original plan. As it was the most cost-effective, at the time. But when the chargeverter came out, it was a cheaper option. And my spares stay new, unless I need them.Yes I bought the growatt 5000es two years ago, it serves my purpose.
see the link in my sig for a DIY version useing server power suppliesIs anyone aware of a functionally similar piece of equipment to the eg4 chargeverter?
Are you replying to OP’s implicit request for things that function like a chargeverter, or the Chargenectifier thread? In the latter thread a lot of the people want a dynamically programmable/configurable charger that can be automated.why would you go through all the hassle? Just purchase another AIO inverter, and feed it generator or whatever power your going to feed to the chargeverter, then you have a backup inverter in case you need one.
I guess with the right AIO you can send it config commands to change the charge parameters but that’s not necessarily better than these CANbus or ModBus things programmable with robust interfaces.
It seems there’s a large class of rackmount etc chargers and power supplies that are programmable via an interface. They definitely support static programming of charging parameters (voltage, current limits, curve, etc), I’m not sure about dynamically changing on the fly though.Does such a device exist? I have a RD6024, which is pretty nice, but obviously doesn't have the specs of a chargeverter (or most inverter/chargers), but I would like to find something like you mention. I scanned through that thread, but most of it appeared to be about CAN bus, which is nice, but not really necessary IMO.
The power quality of the generator is probably related to being able to qualify/synchronize the inverter to it. Chargeverter probably has that disabled, any power factor correction tweaked so that it is more lenient, and removed any firmware logic that would flip out when it sees a bad generator.I'm not sure I follow the use case of "strap output of one 6000XP to another, and feed from generator" ... the manual for the 6000XP states that you must use an inverter-gen
