All of these charge controllers are the "Buck" type. They can only reduce the voltage from the solar array to the batteries. You need the VMP of your solar array to be at least 10 volts over your maximum battery voltage. Common "12 volt" RV solar panels like yours are about 18 volts in the real world, you need at least 7 in series. Can you fit an array that will do that? 2,000 watts of panels will still only make 16 amps of charge current, so you don't need a very high current MPPT controller.
I have seen a few boost type MPPT controllers, but they are very low power, just 10 to 15 amps on the input side, so even less once they step up the voltage, and the ones I am finding top out at just 72 volts.
