Cold Weather Storage for EG4-LL & LiFePOwer4 Batteries
Mainesteader
Penobscot County, ME
I have a 4KW solar setup with 3 of the batteries listed, in server rack style. They are housed in a cabin in Maine which we are prepping to be a full time residence but for now is seasonal.
We closed the cabin down and winterized it, since we won't be back until April. I shut down all breakers and switches and shut each battery down so they won't get any charge from the solar panels. I generator charged all of the batteries to 94% before I shut everything down.
Given the length of time will everything be ok with the batteries? I heard in normal conditions lifepo4 batteries drain at about 2% a month when not used but don't know how cold affects this rate but I've read some say it slows it down even more. The newer LL version 2 batteries state starage temps of -4 to 100+ degrees F, but the manual for my batteries state a higher temperature range suggested for storage. What is the typical discharge rate for a battery in storage? By some estimates that I found (saying they discharge at 2-3% per month) I should still have some charge left in April, but I don't know how dependable those numbers are or if they apply to my batteries. Some people I spoke to said they have the same batteries as mine and did the same thing as me, and they were dead in a similar amount of time (although they said they charged them right back up and they worked just fine).
I'm just making sure the batteries will be ok til April. I estimate they'll have plenty of charge left in them, I'm thinking in terms of integrity and longevity.
Any help/input/wisdom is appreciated
EDIT:
Also, if they do happen to be dead by the time I get up there again, will there be something special I need to do before I turn everything on and plug them in to generator charge? I have this Chargeverter hooked up to the system, and I usually just plug it into my generator when everything is on, and it charges the batteries to full in 2-3 hours. But if the batteries are dead, the chargeverter might not recognize them to start supplying them power, and they might not have any juice to turn on (the batteries themselves) to display stats and other information. Will I have to "jump" the system before I charge them?
Four months is ok for a 94% lifepo4 battery. Some batteries were manufactured at only 30% soc and still active when delivered to customers after 4 months of marine shipping.
Low temperature will hurt the battery's service life so you can try to do something to keep the batteries warm individually.
I believe manual is more reliable than what you may hear from elsewhere.
But then I pulled up the official user manual for my model server rack battery the EG4-LL (the only difference being I have a version 1 and this manual was for version 2), and it listed a storage temp range of -4 degrees F and 113 degrees F suggesting low temps would be fine.
(And the low temperature storage being ok were from threads here from people who tested it out )
If you’re not charging LiFePO4 batteries low temperatures should not be an issue.
In general you want about 50% SOC during storage for LiFePO4.
