GeorgeOrwell1984
Greetings,
I'm in process of building a 8KW PV array that will be controlled by one EG4 6000XP, which will feed one 14.3KWh EG4 PowerPro WallMount battery.
I also have a great opportunity to install a small wind turbine ~500W that will be controlled by dedicated/simple charge controller.
Question: Can two separate charge controllers (PV + wind) be connected to the same battery? If the answer is yes, where can I find more resources so I can ensure everything is done safely.
The goal is to create a hybrid system, that utilizes PV and wind.
Many thanks
Edit: Simplified sketch attached for reference only
Many thanks
