kenkoh
What is the correct order?
This is what I gather from one of Will's video:
1. Connect both positive & negative cables to inverter terminals FIRST
2. Connect inverter negative to battery negative
3. Connect inverter positive (spark) with fuse to battery positive
4. Then connect SCC (does it matter which cable first?)
5. Lastly connect solar panels negative then positive to SCC
6. Disconnect one of solar panels cable FIRST before anything else
Can you connect SCC to Battery first before Inverter? & does negative always go first?
