Can you charge the capacitors from the lead acid battery and then energize the LFP after via contactor relay? Does this capacitor charging process only happen once when the batteries turn on the first time in a trip? Or each time you cycle the inverter on and off?
I had similar architecture in mind on my AGM / LFP mix chemistry system in my RV. I don't want to get rid of the Magnum 2812 or PT100.
I assume the inrush is very momentary (just fraction of 1 second)?
I had planned to just connect the AGM first and then once the inverter was on, turn on the LFP. But in never occurred to me if I turn the inverter on and off on a given trip, the capacitors would need charging again.
Will the inrush also blow a large fuse on the battery (say 300A) like this:
https://www.amazon.com/gp/product/B0019ZBTV4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I bought the Gigavac 200GV contactor from EVwest and planned to have the BMS manage it. It looks pretty similar to what you showed from ECPC.
How can you calculate the inrush current?
Doug
