Hi Filter Guy,
(note, if this long post dilutes the thread, I can remove and post elsewhere, including starting my own thread about my particular mixed chemistry architecture).
Thanks for the thoughts. That certainly seems to work.
Candidly, I had spent some time thinking a few months ago about how I could transition to an LFP battery bank for my RV. My goals were adding substantial capacity to the 660Ah Lifeline bank (3 x 4D) and charging efficiency for my 900W solar setup and some learning without a lot of cost (<$1000 budget for meaningful capacity increase. And long term freeing up storage and weight on the 40k lb bus / RV if I eliminate some AGM batts.)
Knowing the voltage and charging characteristics were different, integration seemed tough. But then I came up with the idea of paralleling both. And considered that the AGMs would just float full in the operating range of the LFP batteries.
Then tapping my friend Google, found some references to hybrid banks as well as
this GREAT FORUM. I know Nordkyn Design site seems to be the gospel around here. Check out his Alternative 1 design:
Electrical design considerations for the integration of lithium battery systems on board marine installations.
nordkyndesign.com
(yes there are pros and cons, which I can accept)
Here's folks using a mixed chemistry battery in practice, which was further validation.
Yet another thread on LiFePo's. I'm getting a bit nearer thinking about putting some LiFePo's on board – purely to reduce the amount of hours I'm running the engine to charge the domestic bank. There were a few great threads at the end of last year and particularly https://www.canalworld.net/foru...
www.canalworld.net
Some of the issues the mixed chemistry solves:
- alternator charging. In my case, the alternator is setup as Constant Voltage. 13.2V. So this happens to be LFP friendly. won't overcharge. But if the BMS disconnects, the alternator still sees AGMs. this is a 400horse cummins with commercial grade alternator. So I expect it could handle full output for a decent duration to get the LFP up to 13.2V if it were @ zero SOC. I still need to think about this.
- occasional high or low ambient temp use. I live in southern California. Usually we camp locally in beach campgrounds. So temps aren't an issue. But if we travel cross country, I could envision having high road temps or possibly caught in cold weather. Then I could just disconnect the LFP (or let the BMS). My bays are heated.
- if I stay long term at a campsite with a shore power, I could just turn off the LFP and float @ whatever voltage.
- if I run the LFP low, the AGM is already connected and operates as normal.
- Now, when I come back from the trip, often the battery isn't 100% charged, so I have to bring it home before putting it in storage to charge overnight. (to maximize AGM life). With mixed, the AGMs should be @ full all the time. I just have to condition the LFP to ~ 50% - wish before parking.
I think my big considerations now are process around flipping the switch. Making sure there isn't massive current flow from the LFP at the time of flipping the switch (including between battery banks). But I can ensure the voltages are similar and the inverter already charged.
PHEW... again, if this dilutes the thread, let me know and I'll rip this out and post elsewhere.
