EASUN lost WiFi
kurnikov
Krsko, Slovenia
I have two Easun SMV IV inverters installed in parallel with a built-in wifi module.
They have been operating normally for several months and are connected to WIFI.
After turning it off and on again when switching on the inverters, one of the inverters no longer connects to wifi.
When the phone searches for wifi I see WiFi_kit_CDA.... instead of the serial name of the converter. I can't connect at all.
Maybe an idea?
I found that with EASUN inverters operating in parallel, the WIFI of the slave units appears to be disabled (i think it is because they are operating as if they were a single inverter). if you switch them back out of parallel mode, all the Wifi modules will be re-enabled and should re-appear on your phone app..
