I don't know if anyone has any experiance with this but my understanding of MPPT is that it will adjust the charging to try to keep the panels producing the most power for a given condition. I have 6 panels with VOC of 220V or something. Given the plate on the panels for optimum output the charge controller should be loading up the panels to somewhere around 180V, and obviously that changes with conditions. I think the algorithm basically adjusts higher or lower and then calculates the power delivered continuosly and so it should always try to maximize P=IV by adjusting V until P is maximal, which sounds complicated but dead easy in the days of microcontrollers.
What I have found recently is that as the day starts it sticks at 120 - 150V all day. I flick the isolator to disconnect the panels at noon and then flick it back on again it settles at 180V and starts pushing andother 10% power. Thats annoying me.
Part of the issue might be down to the fact that my battery is often nearly full so it doesn't end up getting to the optimum / highest current because its already producing more than required. And when you turn the isolator off then when back on briefly there's much more current that can be absorbed by the battery. But its anoying me that I can flick it and cloudy or sun it produces more power.
Maybe someone will know more. I don't there is anything you can really fiddle with for MPPT settings.
There's also one other thing I noticed that coincides. On the panel it shows PV current, when its at 150V it shows 0 but reports correctly over the comms link. After I kicked it and its at 180V then that starts reading correctly like 31A for charging. Thats also annoying me.
There's one thing; accepting when you have cheap hardware that its not going to perform like something thats much more expensive. But its much much more annoying when it shows you what it is capable of doing, but doesn't until you kick it every day. Its like its doing it on purpose.
Sounds like a firmware bug - or not really a bug because it works but not as optimal as it could be. I haven't ever faffed with the firmware version but its not that old so I am assuming its already up to date.
