D. Abineri
I have my 6Kxp on the wall and working well but I am having trouble with a couple of issues:
1. I have used the Maintenance Tab to set the the AC Start Charge at 60% SOC and the AC End Charge at 90% SOC. Nevertheless, my diy 48v battery stays at about 90% all the time. I presume that this means my battery is NOT being used to feed the load very much. I would like the battery to take over some of the load when the PV input drops. How do I set this to happen?
2. On the discharge side, I have the Online End of Discharge to 60% SOC. But I cannor set the Discharge Cut-Off to 50% SOC. It just gives the error that The Operation Failed (error code 3). What are the restrictions on these settings, I cannot find them anywhere.
By the way, I have solar assistant working with the 6Kxp but the Power Tab is not opertional yet which is where the Solar Assistant could have controlled the power usage issues above.
Thanks for any advice on these.
