Hello,
EG4 recommends using their Chargeverter at only 80 amps and not using the full 100 amp output of the charger. They say this is due to heat generated at the full 100 amps (both in their documents and in a phone conversation on their tech line).
Edit: the manual says 85 amps, the tech rep at EG4 said 80 amps.
How many folks are using their Chargeverter at the full 100 amps and has his been a problem for you?
I'll be mounting mine on cement board with 4' of clearance to the top and over a foot on each side and I'd like to use the full 100amp output of the charger to charge a 400ah battery bank. The heat output will actually be desirable in the 50 degree utility room where it will be mounted.
Thanks.
Thanks.
