EG4 DIY mini split
orion7144
South Carolina
I will be installing the 12k btu DIY hybrid but am seeing conflicting installation instructions. The EG4 video ( not the DIY version) shows pumping down the line set before opening the valves. I do not have an issue with that since I have the pump, but my question is other videos show just hooking it up and going with it. Is the charge stored in the condenser or the line set?
Thanks I just want to make sure to get the most life out of the system
Is the charge stored in the condenser or the line set? I believe it's in both.
