conversation I don't see the difference between having properly clamped rings on one post vs having the same number of rings clamped to a bus bar. Please do not be afraid to DIS me I don't care if I am right or wrong I want everybody to learn. Anyways I have never had a problem but that does not mean its correct.
I am only ornery and mean to fools. It’s embarrassing to me when I do it but I’m quite good at it- that’s also to my shame and embarrassing. I wouldn’t diss you.
The critical thing is to not have the battery cable to load more than ‘one step away’ from a load. A busbar should be and is generally at nearly the same resistance as the battery cable terminal itself- when properly installed.
So a busbar is ‘zero resistance’ in practical terms (not scientific terms; everything from wiring to terminal ends has resistance) and is considered as the same as the battery cable.
Problems can and do occur when you two-steps-away a cable with a larger load. I had for quite some time a fla 4P2P 12V battery bank. The 2P was achieved at a single stud terminal block, with the 2/0 main cable to the inside busbar and fusebox etc
sandwiched between the two 4P battery cables- not outside the 2P terminals; “one or zero steps away” in practical terms. Each terminal end sees no more reductions in amp capacity than it would measured alone in practical terms. (Again, there IS a difference scientifically)
However, if you did put the main cable outside there was a decimals voltage difference between the 4P banks measured at full sun (yes, I had to play)
So if (real situation on a ‘customer’ rig) you stacked multiple things on one battery stud - alternator, winch, floodlights, stereo, PDC feed- the battery stud gets very hot to the point of melting wire insulation
and the PDC was even getting hot. One $35 busbar and a coupla hours later and he never melted wires again.
So stacking
can make a difference.
In my own system I have 4-stud busbars. They are full. So when installing the second inverter I landed the inverter feed on top of the main battery feed. This is essentially the same or better than buying busbars with more studs- the load is not ‘removed’ by any “steps away” from the battery cable, and neither the battery cable nor the inverter know the difference.
Some will say that’s pickyuni and I’m not going to argue with that. But my stuff never gets hot, I’ve never blown a fuse or breaker, and it duplicates nothing I’ve seen on people’s stuff I’ve fixed after things got too hot.
A 5A DC load is probably fine in your situation, but my head would still ask the question, “is that terminal end robust enough to let me put 40ftlbs of torque on the nut?”
That’s all - thanks
