Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,094
I disagree. The lug should be in contact with the terminal. The bolt head should have a lock washer and then flat washer up against the lug and on the nut side, a flat washer up against the terminal. Try to use stainless steel. torque correctly. Then torque again after 1-2 minutes as copper tends to relax. if possible, maybe coat the connection with Kopr Kote if concerned about battery acid at the poles in the future.
This talks about a nut as well as a bolt.
Sure, if you put a bolt through a lug and a busbar, you can sandwich the electrical parts with washers on both sides.
Just never put a washer or a nut between electrical parts. We've seen pictures of them glowing red hot.
The drawings presented showed a battery as having the female thread. No nut, so washers only go on bolt head side.
