Extra/Auxilary grounding rods..... Don't do it.
Lightning happens when a really huge negative charge builds up in the ground, corresponding to a positive charge overhead, and the differential becomes sufficient to jump the gap. (and, as others are pointing out repeatedly, air is an excellent insulator, so it takes a whacking huge voltage differential to make the arc.)
A lightning rod doesn't exist to provide a spot for the lightning to strike. Rather, it exists to dissipate the charge so that the strike never happens at all. This comes from early experiments with the Leyden jar; if a pointed metal rod was attached to the jar, it wouldn't charge. The electrons are able to leap off a pointed tip, and into the air, dissipating charge as fast as it accumulates. The lightning rod does the same thing, on a larger scale; it spits out electrons into the air like crazy, so that the charge won't build up sufficiently, and the lightning never hits at all.
Now, if the charge accumulates faster than the rod can dissipate it, there can still be a lightning strike, and the rod typically IS the best route to ground. But everything around the rod is going to take a hell of a jolt anyway, including, most likely, your electronics. A lightning rod getting hit means it failed to work adequately; ideally, it should never be hit at all.
One other tidbit in this case - the lightning rod itself serves as a coronal point. The reason they come to a point it to bring the point of a strike down to a single fine point that will melt when hit. The amount of current in lightning is typically very small compared to the voltage. So by melting the coronal point you can disipate a lot (not all) energy in the strike.
