robby
Photon Vampire
- May 1, 2021
- 4,179
This now makes sense to me. But i wonder why they say you can use it as a Grid Tie Inverter without batteries and add them later?Sol-Ark appears to use switch for GTI control which I explained previously so it's different from typical hybrid inverters that use frequency shift to turn off GTI. Assuming you properly configure the AC coupling settings in Sol-Ark then you don't need to worry about excess GTI power when batteries are full. Basically, Sol-Ark monitors the battery bank SOC and when it's near full it will turn off GTI via the built-in switch to GTI and continue to power loads from the battery bank. When SOC is low enough then the GTI switch will turn on again. I personally like the switch method of GTI control so I don't have to worry about potential problems with frequency shifted power with the devices/appliances I have now or purchase in the future. In general, few electronic devices/appliances are designed and tested to work properly with power frequency outside of the normal grid frequency range.
