Rider
Next was the fridge. I used a 3.5 CF deep chest freezer. It's designed to hold cold better and with a top door, it retains cold when opened. Inserted a thermostat in the power line to regulate it to fridge temps rather than freezer temps. Uses about 1200w on start up for a few seconds, then 90w continuous while actually running. Built an insulated box to hopefully save a few more Kwh. Might not make it thru a rainstorm, but we'll see! A note from supervstech
Fridge is 120VAC, powered by the 1000W inverter.Nice work looks awesome trailer too ? I'm starting to think I should have used a 12v fridge myself. Your weather sounds like mine here in the uk 3 hours sunshine lol
Yeah. I really like the energy savings, but the small size and large expense really ruins it for me. Plus they aren't easy to replace.Mine gets hot on the side that's facing outwards the other 2 are against insulated walls and I've never checked them but yeah I thought same myself. In my country a 12v 3 way fridge is £600. 240v mini fridge perfect for camping and light off grid was £80!! Left me more money to get further along my project for sure. Anything 12v I find is automatically usually very expensive because they like overcharging us happy campers ?
That’s a great idea, but the compressor is designed to operate with the coolant return line lower than fridge temps can produce.
Long term you may be facing compressor failure. Just something you may want to plan for.
To add to that...I have found inverters and power supplies die from insects most often . Attracted to the lights and heat and they get down amongst the Mosfets and poof. Instant carbon track . Good ones will turn off but you turn them back on and they blow. Only way I know so far to change that is a regular clean and some surface spray inside and around outside.
I wanted a small power system for camping, so I used a lot of information gleaned from Will's YouTube vids to put together a system. My main objective was to provide enough power to run a fridge and keep it compact.
The Solar Charge:
As I was walking thru BJs, I spotted a tiered toolbox that would be perfect, that became my electronics package. Solar charge and inverter in the top, storage in the middle and a 100 Ah AGM battery in the base.
View attachment 107View attachment 108
View attachment 109View attachment 110View attachment 111
That is exactly what I'm doing, I take advantage of the thermoclines. I put already frozen 1/2 gallon jugs in the bottom, they stay frozen for months (as long as the freezer is running). If some thing you put in the bottom is not frozen, it will not freeze. Right on the cusp. Things in the top tray stay about 36-38*.Is it possible to use those different temperature levels to keep mostly frozen stuff frozen at the bottom level - ice water jugs, as old storage - and then store stuff like condiments at the top level?
Yea! That's great news!That is exactly what I'm doing, I take advantage of the thermoclines. I put already frozen 1/2 gallon jugs in the bottom, they stay frozen for months (as long as the freezer is running). If some thing you put in the bottom is not frozen, it will not freeze. Right on the cusp. Things in the top tray stay about 36-38*.
The Solar Charge:
