Fusing 48 to 12 Orion DC-DC
jameshowison
I am replacing the system in an RV with a 48v system. I have a Victron 48/12 30amp Orion DC-DC converter. Plan is that 48v Input comes from the busbar, runs through a Midnite DC circuit breaker and into the Orion, 12v leaves and feeds the existing RV 12 volt system.
Victron materials say that the 12/24v units have "Input fuse. On 12V and 24V input models only." And the little manual that comes with it says, "the 12v and 24v input models have an internal fuse (not replaceable). The 48v models do not have this fuse: external fuse required".
I *think* that is talking about fusing the input side, although I'm confused about why one would have a fuse at the end of the wire from the battery (with the internal fuses).
I'm also wondering if I should be fusing the output side, treating it as though it was a 12v battery. If so should I be fusing for the max output (40A) or the short-circuit current (60A). Details on the bottom of the second page, third last column (360W).
The wire run from the Orion to the 12V distribution board will likely be short, like a few feet, but since I haven't located each item yet, it may be up to 15ft (round trip).
I would think you want a fuse by the 12v battery - then your wire to the Dc-dc charger - the wire to your 48v battery then the fuse as it connects to the 48v system.
I think the fuse is for if your wire chafes and shorts you want the fuses to pop so you don’t have a run-away short.
Thanks. I wasn't intending to have a 12v battery, just connect the DC-DC converter directly to the 12v distribution panel. So power would only ever flow from the 48v batteries through the Orion to the 12v distribution panel. Does that change things?
Ok I was thinking a dc-dc charger. For what you have just a fuse by the 48v battery.
You should have a fuse between the bus bars and the Orion DC-DC converter. The fuse must be rated to handle the near 58V of your 48V system (as your other fuses/breakers must as well).
BTW - I don't see a 48V->12V converter that outputs 30A. I just see a single 48V->12V converter that outputs 9A.
Fuses with clearing times designed to protect semiconductors are rare.
Ask how much $ for two of their internal non-replaceable fuses.
Protecting wire insulation with a 50 year life is much easier.
Thanks, that makes sense.
The document is a bit confusing; there are two tables on the second page. The 30A 48/12 is in the second table on p2, third last column.
Ah, so these are the rare times that an (internal) fuse protects the equipment rather than the wire. Hmmm, but Victron says they are non-replaceable so it's odd, they don't seem to protect the equipment and they are at the wrong end of the wire from the battery to protect the wire ...
I believe the non replaceable fuses are so if the dc -dc charger goes up in smoke. The fuse breaks so it doesn’t start a fire with continuous current.
If that fuse pops - your unit is done.
Victron has created a bit of confusion in their product lineup. There is the high power models and then there are the non-high power (my description of this line) models. There is no 48 volt option in the high power line.
High power:
Non-high power:
I know this is an old thread, but did the OP ever find a fuse or breaker to use between the 48v batteries and the 48/12 converter?
I’m trying to build the same thing.
Thanks. Can you recommend what size breaker would be OK? Also what size cables required from the bus bars? My batteries are two 48v eg4 lifepower4. Forgot to label them.
This 48/12 converter provides a continuous 30 amps at 12v, and a max of 40 amps.
Here are the specs:
I use mrbf before and after my DC converters. They support 58v so fine with 48v and look nice and clean.
Here are the specs:
48/12-30 is 30 amps on output, so about 8 amps on input. 10 amp fuse/breaker on input?
We will have multiple 48-12, so using
  • single 48v wire to local busbar, then
  • individual 2-pole MCBs (could use 1 pole of course) to wire inputs (10A for Orion 20, 16A for Orion 30), then
  • orion's, then
  • a multi-circuit blade holder box on the output with blade fuses (25A for Orion 20, 40A for Orion 30), then
  • a split-wire 00/70sqmm output to a Lynx distributor.
Having to use the MCBs is a bit of a pain but 48V (58V) isn't terribly easy. This way should be easier (on/off capability vs blow fuse) and cheaper (!) than multiple MRBF's on the input. 12v on output makes it a lot easier until the large final wires to the major 12V busbar.
  • orion's, then
Mine looks like this. It's 24 coming in from alternator into 24/48 and 24/12 orions. Large fuse close to the alternator so nothing coming in but all outbound uses mrbf. They go into lynxs with additional fuses in there.
My 12v wiring now sits on top. Very happy with the setup and at some point I'll add fans to keep the orions cool
