The time eventually comes that all those temporary and make do methods you used to test out this solar power stuff needs to be redone and prettied up some. The solar panels propped up on concrete blocks in the yard, with whatever wire you could find hooked to it by rather dubious connection methods, needs upgrade. The SCC/AIO really ought to not be hanging on the back wall wrapped in a plastic bag for protection from the rain. Your batteries should not be tucked under the bed for safekeeping and the inverter's output should not be connected to the house's main panel with a couple of wire nuts (or Wagos if you had money for them) via a back fed breaker. Various rats nest of wires should be sorted through and some labeling could be done.
Time to go back and make your setup look like it was designed and not evolved from from the primordial ooze. You know it works but is it something you would want your friends and neighbors to see?
