An inverter turns DC power into AC power.Grid-forming inverters should be installed in DC side or AC side?
So we don't have DC/DC or AC/AC inverters?An inverter turns DC power into AC power.
They are installed between the two.
No those would be converters and transformers.So we don't have DC/DC or AC/AC inverters?
The controller is what forms your micro grid. It also controls the generation of all sources by increasing/decreasing the frequency slightly to let them know what to do. No doubt others know more on this topic. The only setup I know of like that is one that involves a Victron Multiplus II as a controller and the battery inverter/charger in one. I think the advantage of this is that you need at least one device on this micro grid that can respond to demand/oversupply much quicker than what it takes to measure the frequency of the AC. The Multiplus being the master and having a battery it can use as a source/sink can do that to stabilise the microgrid even if it takes time to spin other sources up or down.My another question is control of microgrid. If these inverters can control the voltage and frequency, why do we need to add another controller for microgrid? The figure below shows a separate controller in addition to the inverters.
Most hybrid inverter do.Do we have multi-mode inverter for grid-connection?
I mean an inverter with grid-forming and grid-following mode.
Do you know any brand for these type of inverters?
Thanks. We call this controller energy management system (EMS). Right?The controller is what forms your micro grid. It also controls the generation of all sources by increasing/decreasing the frequency slightly to let them know what to do. No doubt others know more on this topic. The only setup I know of like that is one that involves a Victron Multiplus II as a controller and the battery inverter/charger in one. I think the advantage of this is that you need at least one device on this micro grid that can respond to demand/oversupply much quicker than what it takes to measure the frequency of the AC. The Multiplus being the master and having a battery it can use as a source/sink can do that to stabilise the microgrid even if it takes time to spin other sources up or down.
Thanks. It was very informative.Most hybrid inverter do.
- Pass-through relay open, grid forming.
- Pass-through relay closed, grid following.
Closing pass-through relay is based on first detecting AC voltage present on AC input then aligning inverter's voltage/freq/phase (becoming a slave) before closing pass-through relay.
Some newer systems place the grid disconnect relay external from hybrid inverter, between utility input lines and main panel and allow multiple hybrid inverters and/or PV GT inverters to provide AC feed power directly to main panel. Again, pass-through relay open means grid forming, with one of the units feeding panel being reference master.
Providing power contribution does not mean a source is phase master, although it can help lower micro-grid mastering impedance.
Unfortunately I have no idea. I doubt the victron Multiplus II manual I read specified it. I seriously considered this setup for myself for a while, only deciding against it based on price.Thanks. Which type of control algorithm/strategy is used for this controller? (i.e., PID, adaptive controller, ...)
If the main grid is outage, what's your suggestion about control strategy to maintain stable voltage and frequency?Most hybrid inverter do.
The inverter will take care of thatIf the main grid is outage, what's your suggestion about control strategy to maintain stable voltage and frequency?
Thanks. But beside the inverters, we need to have separate controller (energy management system) to control and manage the power flow. Like the following picture.The inverter will take care of that
So, it works like EMS. Right?Depends upon the inverter used, my SMA Sunny Islands include the controller and use frequency shift to control output of connected PV inverters.
I couldn't find Early Sunny Islands datasheet. Could you please share the link?Early Sunny Islands
