Yukonelius
- Mar 24, 2022
- 1
Hello,
New to the forum, not so new to the youtube Channel.
I found a great deal on some FS-4102A Solar Panels... the problem is they are higher voltage, 88v open circuit.
Here is the data sheet...
My question is more a of sanity check and discussion than anything else...
With these panels being 88v I feel that it is going to be hard to find an inverter that will accept any series connections but because they are like 1.5amps each I could see wiring them in a large parallel configuration.
Are there inverters that can accept like 2 (or 3) in series and then 10 in parallel? I am wanting to use about 30 of them for my application and I want it to store to batteries and backed up by the grid.
Would I just wire them all in parallel to get them to basically 88v and 45amps? This is where I am stumped.
Should I just skip these all together and get something more standard? I liked these because I was going to make them into a patio cover that also will let some light through.
