Most of the existing videos/articles on selecting MPPT controller does NOT consider Maximum Charge current of the battery.
I have few question regarding this,
Say a 24v/50AH LifePo4 battery used with a 1100W(total power) solar panels.
Assuming safe charge current of the battery is 25A (i.e. 0.5C).
(and assuming the availability of a MPPT controller with Max-60A with the capability to control max charging current)
Do I have to limit Maximum charge current of the MPPT controller to 25A ? (i.e. If I am expecting to use the battery for a long time)
If so, does it mean maximum continuous power I can draw (when there is sufficient Sun light AND without draining the battery) from the unit is 24vx25A => 600W
Also does it mean that if I want to use the full capacity of the Solar panels, I have to switch to battery with higher capacity(e.g. 24v/100AH) ?
