Brucey
Solar Wizard
Yes looks like some BMS protocols allow both devices on the one chain, this would generally be if you had some ve.can connected mppts to connect as well. I would treat it as an either/or option to avoid disappointment. If you have ve.can devices to monitor in addition to BMS connectivity then spring for the full fat GX.Yupp but there's this option to change the vecan middle ports to can-bus. Actually might even be able to use both vecan and canbus
